Salta al contenuto principale
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: passo 1, immagine 1 di 2 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: passo 1, immagine 2 di 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: passo 2, immagine 1 di 2 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: passo 2, immagine 2 di 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: passo 3, immagine 1 di 2 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: passo 3, immagine 2 di 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Conclusione
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 378
