Salta al contenuto principale
Toshiba Satellite M305D-S4829 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 4, immagine 2 di 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 5, immagine 2 di 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 6, immagine 2 di 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 7, immagine 2 di 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: passo 8, immagine 1 di 1
    • Your keyboard has now been successfully removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-3, Regan Spring 2011 Membro di Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,580
