Salta al contenuto principale
Toshiba Satellite M305D-S4829 Fan Replacement
Cosa ti serve
  1. Toshiba Satellite M305D-S4829 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Fan Replacement: passo 2, immagine 1 di 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Fan Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Fan Replacement: passo 4, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 4, immagine 2 di 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Fan Replacement: passo 5, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 5, immagine 2 di 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Fan Replacement: passo 6, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 6, immagine 2 di 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Fan Replacement: passo 7, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 7, immagine 2 di 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Fan Replacement: passo 8, immagine 1 di 1
    • Your keyboard has now been successfully removed.
  9. Toshiba Satellite M305D-S4829 Fan Replacement, CD/DVD Drive: passo 9, immagine 1 di 1
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  10. Toshiba Satellite M305D-S4829 Fan Replacement: passo 10, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 10, immagine 2 di 2
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  11. Toshiba Satellite M305D-S4829 Fan Replacement: passo 11, immagine 1 di 1
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  12. Toshiba Satellite M305D-S4829 Fan Replacement: passo 12, immagine 1 di 1
    • Gently remove the CD/DVD drive from the laptop body.
  13. Toshiba Satellite M305D-S4829 Fan Replacement, also remove these two screws: passo 13, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement, also remove these two screws: passo 13, immagine 2 di 2
    • Remove the circled screws with Phillips #0 screwdriver.
  14. Toshiba Satellite M305D-S4829 Fan Replacement: passo 14, immagine 1 di 1
    • Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
  15. Toshiba Satellite M305D-S4829 Fan Replacement: passo 15, immagine 1 di 1
    • Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
    • Note: Yours may only have two (2) antennas. Pay attention to the Orientation of the Aluminum bracket with the pads for reinstallation.
  16. Toshiba Satellite M305D-S4829 Fan Replacement: passo 16, immagine 1 di 1
    • Remove the circled screw with a Phillips #0 screwdriver.
  17. Toshiba Satellite M305D-S4829 Fan Replacement: passo 17, immagine 1 di 1
    • Detach the 3 marked cables by pulling them out with you fingers as shown.
    • This may require some force. They do not come out easily.
  18. Toshiba Satellite M305D-S4829 Fan Replacement: passo 18, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Detach the four blue ribbon cables carefully with tweezers. Some of the ribbons may require a flap to be raised because it secures the ribbon in.
  19. Toshiba Satellite M305D-S4829 Fan Replacement: passo 19, immagine 1 di 1
    • Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
  20. Toshiba Satellite M305D-S4829 Fan Replacement: passo 20, immagine 1 di 1
    • Remove the circled motherboard screws with a Phillips #0 Scewdriver.
    • Disconnect this ribbon cable.
  21. Toshiba Satellite M305D-S4829 Fan Replacement: passo 21, immagine 1 di 1
    • Remove these screws with a Phillips #0 screwdriver.
  22. Toshiba Satellite M305D-S4829 Fan Replacement: passo 22, immagine 1 di 1
    • Detach the display cable by gently pulling it out with your fingers.
  23. Toshiba Satellite M305D-S4829 Fan Replacement: passo 23, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 23, immagine 2 di 2
    • Remove the motherboard from the left side by gently lifting the left side upward.
    • The boxed volume control may snag on the laptop frame when pulling the motherboard out.
  24. Toshiba Satellite M305D-S4829 Fan Replacement: passo 24, immagine 1 di 1
    • The motherboard has now been removed from laptop.
  25. Toshiba Satellite M305D-S4829 Fan Replacement, Fan: passo 25, immagine 1 di 1
    • Detach the fan power cord by pulling it out with your fingers.
    • Carefully lift up the tape on the fan by peeling the right edge to the left. It can remain attached to the heatsink but should be removed from the fan.
  26. Toshiba Satellite M305D-S4829 Fan Replacement: passo 26, immagine 1 di 1
    • Remove the circled screws with a Phillips #0 screwdriver.
  27. Toshiba Satellite M305D-S4829 Fan Replacement: passo 27, immagine 1 di 3 Toshiba Satellite M305D-S4829 Fan Replacement: passo 27, immagine 2 di 3 Toshiba Satellite M305D-S4829 Fan Replacement: passo 27, immagine 3 di 3
    • Locate the 3 circled clips holding the fan to the motherboard.
    • Pry each clip outward while applying upward force on the fan as shown.
  28. Toshiba Satellite M305D-S4829 Fan Replacement: passo 28, immagine 1 di 2 Toshiba Satellite M305D-S4829 Fan Replacement: passo 28, immagine 2 di 2
    • Carefully pull out the fan.
    • Note: replacing the fan is highly reccomended
    • Optionally you may clean the fan with Air + Q-Tips. To remove the blade turn the fan over and gently pull the fan blade from the housing.
    • If the fan is no longer operational, it may be possible to temporarily repair it by removing the fan blade and put a small amount of WD-40 on the pinion shaft hole the fan rotates in. A toothpick is a good applicator. Do NOT contaminate the motor area with any of the dust/grime that has accumulated.
    • Insert the fan blade and move the blades with your finger. It should spin freely and cog to a stop. Again this is a temporary fix!
Conclusione
Cal Poly, Team 4-3, Regan Spring 2011 Membro di Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 5,922
