Salta al contenuto principale
Toshiba Satellite L855-S5119 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: passo 1, immagine 1 di 3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: passo 1, immagine 2 di 3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: passo 1, immagine 3 di 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 2 Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  3. Toshiba Satellite L855-S5119 Optical Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L855-S5119 Optical Drive Replacement: passo 3, immagine 2 di 2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 282
