Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will inform readers on how to replace the optical drive which may have stopped reading disks.
  1. Turn the laptop over to place it top down. Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate. Lift the back plate off the laptop, exposing the RAM and Hard Disk.
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Using a Phillips #0 screwdriver, remove the single 3mm screw. Using a Phillips #0 screwdriver, remove the single 3mm screw.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  4. Rotate the laptop so that you have access to the optical drive. The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 123
