Salta al contenuto principale
Toshiba Satellite L775D-S7340 Optical Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 2, immagine 1 di 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 3, immagine 1 di 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Optical Disk Drive: passo 4, immagine 1 di 1
    • Remove the (mm) screw in between the two white manufacturer’s stickers using the Phillips #1 screwdriver.
  5. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: passo 5, immagine 1 di 1
    • Gently slide the optical disk drive out of the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 244
