Salta al contenuto principale
Toshiba Satellite L775D-S7340 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: passo 7, immagine 1 di 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Conclusione
Un commento
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,702
