Salta al contenuto principale
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: passo 1, immagine 2 di 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: passo 2, immagine 1 di 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 3, immagine 1 di 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 4, immagine 1 di 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, immagine 1 di 1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 6, immagine 2 di 2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 7, immagine 1 di 1
    • Remove the two 4mm screws and the plate attached to the ODD.
Conclusione
USF Tampa, Team 2-5, Sullivan Fall 2016 Membro di USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 347
