Salta al contenuto principale
Toshiba Satellite L755-S5244 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L755-S5244 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Toshiba Satellite L755-S5244 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Begin by unscrewing the screw located underneath the battery.
    • Then, unsnap and remove the bar above the keyboard.
  2. Toshiba Satellite L755-S5244 Keyboard Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 4mm Phillips #0 screws beneath the bar.
  3. Toshiba Satellite L755-S5244 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L755-S5244 Keyboard Replacement: passo 3, immagine 2 di 2
    • Pull keyboard up and partially out.
    • Detach conductor ribbon.
    • Slide keyboard out completely.
Conclusione
Un commento
Step One -On my Toshiba L755-S5244 there is a screw accessible from the battery bay that holds this bar in place.
Mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,195
