Salta al contenuto principale
Toshiba Satellite L755-S5244 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L755-S5244 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Toshiba Satellite L755-S5244 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • As a safety precaution, unplug the laptop and remove the battery.
  2. Toshiba Satellite L755-S5244 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the two 3mm Phillips #0 screws on the bottom of the corner panel.
    • The screws do not need to be removed completely from the panel, just loosened out of the sockets beneath the panel. When the screws are completely loosened, they can be left in the panel.
  3. Toshiba Satellite L755-S5244 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use the cutaway to lift the panel away from the lap top.
  4. Toshiba Satellite L755-S5244 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the single 3mm Phillips #0 screw securing the hard drive (hard drive not pictured).
    • Once the screw is removed, push the hard drive up (away from the battery) to disconnect it from the laptop.
    • You are now able to lift the hard drive out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 767
