Salta al contenuto principale
Toshiba Satellite L675D-S7016 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: passo 2, immagine 1 di 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L675D-S7016 RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L675D-S7016 RAM Replacement: passo 3, immagine 3 di 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: passo 4, immagine 1 di 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite L675D-S7016 RAM Replacement: passo 5, immagine 2 di 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: passo 6, immagine 1 di 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: passo 6, immagine 2 di 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: passo 6, immagine 3 di 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L675D-S7016 RAM Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L675D-S7016 RAM Replacement: passo 7, immagine 3 di 3
    • Repeat the same procedure to remove the second stick of RAM.
Conclusione
Austin Bons
Membro da: 09/22/16
1.131 Reputazione
8 Guide realizzate
UC Davis, Team 2-2, Oliver Fall 2016 Membro di UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 22
Tutti i Tempi: 637
