Salta al contenuto principale
Toshiba Satellite L675D-S7016 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: passo 4, immagine 1 di 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
Conclusione
To install a new Hard Drive, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Austin Bons
Membro da: 09/22/16
1.131 Reputazione
8 Guide realizzate
UC Davis, Team 2-2, Oliver Fall 2016 Membro di UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,091
