Salta al contenuto principale
Toshiba Satellite L675D-S7016 Battery Replacement
  1. Toshiba Satellite L675D-S7016 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Battery Replacement: passo 2, immagine 1 di 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, immagine 3 di 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
Conclusione
To reassemble your device, follow the steps in reverse order.
UC Davis, Team 2-2, Oliver Fall 2016 Membro di UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membri
10 Guide realizzate
2 Commenti
Where would I purchase a battery for a Toshiba L675 laptop? Price?
mford811 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 24
Tutti i Tempi: 681
