Salta al contenuto principale
Toshiba Satellite L675D-S7015 Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop on a scratch free surface, exposing underneath the laptop.
    • Identify the unlocking latches denoted by the red circles.
  2. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 2, immagine 2 di 2
    • Simply slide the latches outward to the unlocked position.
    • The latches should stay in the unlocked position. If not, hold them in the unlocked position.
    • With the latches in the unlocked position, slide the battery out, away from the laptop.
  3. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: passo 3, immagine 1 di 2 Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: passo 3, immagine 2 di 2
    • Remove the the screw shown by the red circle.
    • Lift and remove the panel shown.
  4. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 4, immagine 1 di 1
    • Remove the screw shown by the red circle.
    • Locate the small square that shows the back edge of the disk drive.
    • Push the drive in the direction shown until it cannot be pushed any further.
  5. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 5, immagine 1 di 1
    • Pull the now revealed part of the disk drive in the direction shown until the disk drive is released.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 112
