Salta al contenuto principale
Toshiba Satellite L670 HDD replacement
Cosa ti serve
  1. Toshiba Satellite L670 HDD replacement, Turn off the computer: passo 1, immagine 1 di 1
    • Turn off the computer and unplug the power from the computer.
  2. Toshiba Satellite L670 HDD replacement, Flip Laptop: passo 2, immagine 1 di 1
    • Turn the laptop upside down. Locate the two latches on either side of the battery.
    • Now the battery comes off.
  3. Toshiba Satellite L670 HDD replacement, Remove battery: passo 3, immagine 1 di 2 Toshiba Satellite L670 HDD replacement, Remove battery: passo 3, immagine 2 di 2
    • Remove the battery
  4. Toshiba Satellite L670 HDD replacement, Remove rear panel: passo 4, immagine 1 di 2 Toshiba Satellite L670 HDD replacement, Remove rear panel: passo 4, immagine 2 di 2
    • Remove the back plate
  5. Toshiba Satellite L670 HDD replacement, Remove the HDD: passo 5, immagine 1 di 2 Toshiba Satellite L670 HDD replacement, Remove the HDD: passo 5, immagine 2 di 2
    • Pull the HDD to the left using the silver tab.
    • Pull up on the silver tab and remove the hard drive from the slot.
  6. Toshiba Satellite L670 HDD replacement, Unscrew the HDD cover: passo 6, immagine 1 di 2 Toshiba Satellite L670 HDD replacement, Unscrew the HDD cover: passo 6, immagine 2 di 2
    • Remove the 4 screws from the hard drive.
  7. Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: passo 7, immagine 1 di 3 Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: passo 7, immagine 2 di 3 Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: passo 7, immagine 3 di 3
    • Take your new SSD hard drive.
    • Place the SSD in the silver case.
    • Place back the 4 screws you just removed.
  8. Toshiba Satellite L670 HDD replacement, Insert SSD: passo 8, immagine 1 di 2 Toshiba Satellite L670 HDD replacement, Insert SSD: passo 8, immagine 2 di 2
    • Insert the SSD into the laptop.
    • Slide the SSD to the right into the socket.
  9. Toshiba Satellite L670 HDD replacement, Place back panel + battery: passo 9, immagine 1 di 1
    • Replace the back panel and screw it in place.
    • Put the battery back in, you will hear a click once it falls into place.
Conclusione
To reassemble the device, follow these instructions in reverse order.
Un ringraziamento speciale a questi traduttori:
nl en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
levi lenaers
Membro da: 09/24/16
190 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 51
Tutti i Tempi: 1,411
