Salta al contenuto principale
Introduzione
This guide replaces the RAM in your laptop and is fairly simple to complete.
  1. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  4. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up.
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  5. Pull the top RAM stick out gently. Repeat steps 3 and 4 for the bottom RAM stick. When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
Conclusione
Altre 8 persone hanno completato questa guida.
Jerry Wakai
Membro da: 31/01/2013
335 Reputazione
4 Guide realizzate
Cal Poly, Team 7-7, Maness Winter 2013 Membro di Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membri
6 Guide realizzate
Thank-You! So Much!
Sandra Crockett - Replica
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,222
