Salta al contenuto principale
Toshiba Satellite L655D-S5095 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 2, immagine 1 di 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 5, immagine 2 di 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 6, immagine 1 di 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 7, immagine 1 di 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Jerry Wakai
Membro da: 01/31/13
377 Reputazione
4 Guide realizzate
Cal Poly, Team 7-7, Maness Winter 2013 Membro di Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membri
6 Guide realizzate
2 Commenti
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Replica
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 4,923
