Salta al contenuto principale
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 2 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 2 di 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 2, immagine 1 di 1
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 3, immagine 1 di 1
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 5, immagine 1 di 1
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Conclusione
Torey
Membro da: 01/31/13
210 Reputazione
1 Guida realizzata
Cal Poly, Team 7-7, Maness Winter 2013 Membro di Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,306
