Salta al contenuto principale
Toshiba Satellite L55t-B5271 Wireless Card Replacement
Cosa ti serve
  1. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 2, immagine 2 di 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 3, immagine 3 di 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: passo 4, immagine 1 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: passo 4, immagine 2 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: passo 5, immagine 1 di 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: passo 5, immagine 2 di 2
    • Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
  6. Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 6, immagine 1 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 6, immagine 2 di 3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 6, immagine 3 di 3
    • Remove the tape from the card.
    • Disconnect the wires using the #4 black spudger tool.
  7. Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 7, immagine 1 di 1
    • Remove the 3mm Phillips head screw with a Phillips #00 screwdriver.
  8. Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 8, immagine 1 di 2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: passo 8, immagine 2 di 2
    • Pull up on the wireless card and remove it from the device.
Conclusione
Noelle Dulude
Membro da: 03/19/18
480 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 313
