Salta al contenuto principale
Toshiba Satellite L55t-B5271 CD Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 2, immagine 2 di 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 3, immagine 3 di 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: passo 4, immagine 1 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: passo 4, immagine 2 di 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: passo 5, immagine 1 di 2 Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: passo 5, immagine 2 di 2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  6. Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: passo 6, immagine 2 di 2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 305
