Salta al contenuto principale
Toshiba Satellite L505D-GS6000 Key Replacement
Cosa ti serve
  1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: passo 1, immagine 1 di 3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: passo 1, immagine 2 di 3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: passo 1, immagine 3 di 3
    • Open laptop in the front facing position.
    • Use a plastic opening tool to remove the desired key from the keyboard.
    • When lifting up on the key, do so carefully as to not break the key or its housing underneath.
  2. Toshiba Satellite L505D-GS6000 Key Replacement: passo 2, immagine 1 di 1
    • Use a finger to push a new key into place.
Conclusione
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 459
