Salta al contenuto principale
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: passo 2, immagine 1 di 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: passo 3, immagine 1 di 1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: passo 4, immagine 1 di 1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 358
