Salta al contenuto principale
Toshiba Satellite L505D-GS6000 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Battery Replacement: passo 2, immagine 1 di 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 332
