Salta al contenuto principale
Toshiba Satellite L505 Laptop Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 3, immagine 2 di 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, immagine 1 di 3 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, immagine 2 di 3 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, immagine 3 di 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,287
