Introduzione
The wifi card enables the computer to be compatible with wifi. If the card is malfunctioning, the computer will not receive a signal from any wifi sources. This guide shows how to remove the wifi card so it can be replaced.
Cosa ti serve
Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
Remove the two Phillips #1 6mm screws from the wifi card using a Phillips #1 screwdriver.
Unsnap the two cables from the wifi card.
Altre 4 persone hanno completato questa guida.
