Salta al contenuto principale
Toshiba Satellite L455D-S5976 CPU Replacement
Cosa ti serve
  1. Toshiba Satellite L455D-S5976 CPU Replacement, Battery: passo 1, immagine 1 di 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 CPU Replacement: passo 2, immagine 1 di 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 CPU Replacement: passo 3, immagine 1 di 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 CPU Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 CPU Replacement: passo 5, immagine 1 di 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 CPU Replacement: passo 6, immagine 1 di 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 CPU Replacement: passo 7, immagine 1 di 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 CPU Replacement: passo 8, immagine 1 di 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 CPU Replacement: passo 9, immagine 1 di 2 Toshiba Satellite L455D-S5976 CPU Replacement: passo 9, immagine 2 di 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, immagine 1 di 3 Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, immagine 2 di 3 Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, immagine 3 di 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 CPU Replacement: passo 11, immagine 1 di 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 CPU Replacement: passo 12, immagine 1 di 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 CPU Replacement: passo 13, immagine 1 di 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, immagine 1 di 3 Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, immagine 2 di 3 Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, immagine 3 di 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 CPU Replacement: passo 15, immagine 1 di 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 CPU Replacement: passo 16, immagine 1 di 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
  17. Toshiba Satellite L455D-S5976 CPU Replacement, CPU: passo 17, immagine 1 di 1
    • Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
  18. Toshiba Satellite L455D-S5976 CPU Replacement: passo 18, immagine 1 di 1
    • Remove the two cables from the fan.
  19. Toshiba Satellite L455D-S5976 CPU Replacement: passo 19, immagine 1 di 2 Toshiba Satellite L455D-S5976 CPU Replacement: passo 19, immagine 2 di 2
    • LIft up on the fan and remove it from the computer.
  20. Toshiba Satellite L455D-S5976 CPU Replacement: passo 20, immagine 1 di 1
    • Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
  21. Toshiba Satellite L455D-S5976 CPU Replacement: passo 21, immagine 1 di 1
    • Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
  22. Toshiba Satellite L455D-S5976 CPU Replacement: passo 22, immagine 1 di 2 Toshiba Satellite L455D-S5976 CPU Replacement: passo 22, immagine 2 di 2
    • Remove the motherboard with your hands by carefully lifting up and pulling out.
  23. Toshiba Satellite L455D-S5976 CPU Replacement: passo 23, immagine 1 di 2 Toshiba Satellite L455D-S5976 CPU Replacement: passo 23, immagine 2 di 2
    • Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
  24. Toshiba Satellite L455D-S5976 CPU Replacement: passo 24, immagine 1 di 2 Toshiba Satellite L455D-S5976 CPU Replacement: passo 24, immagine 2 di 2
    • Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
    • Remove the CPU by lifting up on the chip.
Conclusione
Altre 11 persone hanno completato questa guida.
NateJohnson
Membro da: 01/26/14
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team 9-26, Maness Winter 2014 Membro di Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Membri
5 Guide realizzate
Un commento
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,826
