Salta al contenuto principale
Toshiba Satellite L455-S5046 Optical Drive Replacement
Cosa ti serve
Panoramica Video
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 4, immagine 2 di 2
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 200
