Salta al contenuto principale
Toshiba Satellite L455-S5046 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
    • Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
  2. Toshiba Satellite L455-S5046 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L455-S5046 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 399
