Salta al contenuto principale
Toshiba Satellite L455-S5046 Hard-drive Replacement
Cosa ti serve
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: passo 1, immagine 2 di 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: passo 2, immagine 1 di 1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: passo 3, immagine 1 di 1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 321
