Salta al contenuto principale
Toshiba Satellite L45-S7423 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 3, immagine 2 di 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: passo 4, immagine 2 di 3 Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: passo 4, immagine 3 di 3
    • Remove the two screws holding the hard drive panel down.
    • These screw are permanently fastened to the panel; they are designed to be removed only partially.
  5. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Use a finger to lift up on the tab and remove the panel.
  6. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 6, immagine 2 di 2
    • Remove the screw that holds in place the optical drive.
    • One 4.6 mm Phillips screw.
  7. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 7, immagine 1 di 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 7, immagine 2 di 2
    • Locate the small rectangular hole and insert the spudger.
    • Gently slide the metal flange to the right to dislodge the optical drive.
  8. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 8, immagine 1 di 1
    • The optical drive will become partially exposed.
  9. Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 9, immagine 1 di 2 Toshiba Satellite L45-S7423 Optical Drive Replacement: passo 9, immagine 2 di 2
    • Pull the optical drive to remove it from the computer body.
Conclusione
Cal Poly, Team 21-54, Johann Spring 2013 Membro di Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Membri
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 923
