Salta al contenuto principale
Toshiba Satellite L45-S7423 LCD Display Replacement
Cosa ti serve
  1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 3, immagine 2 di 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: passo 4, immagine 3 di 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 5, immagine 3 di 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: passo 6, immagine 3 di 3
    • Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
    • This screw is not designed to be completely removed, it is permanently fastened to the panel to avoid loss.
  7. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 7, immagine 3 di 3
    • With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
  8. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 8, immagine 1 di 1
    • Remove the yellow tape holding the black and the white wires in place.
  9. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 9, immagine 3 di 3
    • Unwind the wires from the plastic tabs holding the wires in place.
  10. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 10, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 10, immagine 2 di 2
    • Remove the screw holding the ground cable in place.
    • One 4.5 mm Phillips screw.
  11. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 11, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 11, immagine 2 di 2
    • Disconnect the video cable connecting the display to the base of the laptop.
  12. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 12, immagine 3 di 3
    • Pop off the laptop's hinge covers using a spudger tool.
    • Only a small amount of force is required. Excessive force may permanently damage the hinge covers.
  13. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 13, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 13, immagine 2 di 2
    • Remove the two screws on the back side of the laptop holding the LCD display in place.
    • Two 8.5 mm Phillips screws.
  14. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 14, immagine 1 di 2 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 14, immagine 2 di 2
    • Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
  15. Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, immagine 1 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, immagine 2 di 3 Toshiba Satellite L45-S7423 LCD Display Replacement: passo 15, immagine 3 di 3
    • Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
    • Be careful as you remove the display not to pull too hard on the cables as they pass through the opening.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 21-54, Johann Spring 2013 Membro di Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,895
