Salta al contenuto principale
Toshiba Satellite L45-S7423 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove the two Phillips screws holding the panel in place.
    • These screws cannot be removed completely from the panel. They are fastened to the panel to avoid loss.
  5. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 5, immagine 1 di 1
    • To remove, lift up the panel's tab.
  6. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, immagine 1 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, immagine 2 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, immagine 3 di 3
    • Remove the screws attaching the hard drive and bracket.
    • Four 4.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Lift up the black tab to expose hard drive.
    • Grab the hard drive bracket and pull to remove.
  8. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 8, immagine 1 di 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 8, immagine 2 di 2
    • Remove the screws attaching the hard drive to hard drive bracket.
    • Four 3.6 mm Phillips screws.
  9. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 9, immagine 1 di 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 9, immagine 2 di 2
    • Separate the hard drive from hard drive bracket to complete removal.
Conclusione
Cal Poly, Team 21-54, Johann Spring 2013 Membro di Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,669
