Salta al contenuto principale
Toshiba Satellite L35-S2174 Screen Replacement
Cosa ti serve
  1. Toshiba Satellite L35-S2174 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Screen Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 2, immagine 2 di 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Screen Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 3, immagine 2 di 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Screen Replacement: passo 4, immagine 1 di 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: passo 5, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement, Keyboard: passo 5, immagine 2 di 2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Screen Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 6, immagine 2 di 2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Screen Replacement: passo 7, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 7, immagine 2 di 2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Screen Replacement: passo 8, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 8, immagine 2 di 2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Screen Replacement: passo 9, immagine 1 di 1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  10. Toshiba Satellite L35-S2174 Screen Replacement, Screen: passo 10, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement, Screen: passo 10, immagine 2 di 2
  11. Toshiba Satellite L35-S2174 Screen Replacement: passo 11, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 11, immagine 2 di 2
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the plastic panel.
  12. Toshiba Satellite L35-S2174 Screen Replacement: passo 12, immagine 1 di 3 Toshiba Satellite L35-S2174 Screen Replacement: passo 12, immagine 2 di 3 Toshiba Satellite L35-S2174 Screen Replacement: passo 12, immagine 3 di 3
    • Gently lift and detach the grey and black antennae cables that are attached to the blue circuitboard.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
  13. Toshiba Satellite L35-S2174 Screen Replacement: passo 13, immagine 1 di 1
    • Flip the laptop over.
    • Pull the black and grey cables out of the laptop, towards the laptop screen.
    • The cables are connected to the screen.
  14. Toshiba Satellite L35-S2174 Screen Replacement: passo 14, immagine 1 di 2 Toshiba Satellite L35-S2174 Screen Replacement: passo 14, immagine 2 di 2
    • Detach the black cable from the computer by pulling it to the right.
  15. Toshiba Satellite L35-S2174 Screen Replacement: passo 15, immagine 1 di 1
    • Lift the screen away from the laptop.
Conclusione
UMass Dartmouth, Team 1-4, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 426
