Salta al contenuto principale
Toshiba Satellite L35-S2174 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 4, immagine 1 di 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
Conclusione
UMass Dartmouth, Team 1-4, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 598
