Salta al contenuto principale
Toshiba Satellite L305D-S5950 Motherboard Cover Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 2, immagine 2 di 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 3, immagine 2 di 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: passo 5, immagine 1 di 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: passo 5, immagine 2 di 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 6, immagine 1 di 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, immagine 3 di 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 8, immagine 1 di 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: passo 9, immagine 1 di 2 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: passo 9, immagine 2 di 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, immagine 1 di 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, immagine 2 di 3 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, immagine 3 di 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
Conclusione
Clemson, Team 1-2, Benson Spring 2014 Membro di Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Membri
10 Guide realizzate
0 Guide Comments
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 317
