Salta al contenuto principale
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 2, immagine 2 di 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 3, immagine 2 di 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: passo 5, immagine 1 di 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: passo 5, immagine 2 di 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 6, immagine 1 di 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 7, immagine 1 di 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 7, immagine 2 di 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, immagine 1 di 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, immagine 2 di 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, immagine 3 di 3
    • To separate the hard drive from the caddy, unscrew the two screws.
Conclusione
Ricky Baker
Membro da: 03/26/14
217 Reputazione
2 Guide realizzate
Clemson, Team 1-2, Benson Spring 2014 Membro di Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 864
