Salta al contenuto principale
Toshiba Satellite L305D-S5900 Storage Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, immagine 3 di 3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 3, immagine 2 di 2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Conclusione
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 376
