Salta al contenuto principale
Toshiba Satellite L305D-S5900 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, immagine 2 di 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, immagine 3 di 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Conclusione
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 247
