Salta al contenuto principale
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 2, immagine 2 di 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 3, immagine 2 di 2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 4, immagine 1 di 1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: passo 5, immagine 1 di 1
    • Fully remove the drive by pulling it all the way out of its socket.
Conclusione
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 650
