Salta al contenuto principale
Toshiba Satellite L305D-S5900 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L305D-S5900 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly.
    • The plastic strip boxed in red is located above the keyboard of the computer.
  2. Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 2, immagine 3 di 3
    • There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
    • Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
  3. Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.3 mm Phillips #1 screws that are beneath the strip.
    • The screws located at the far left and far right when the plastic strip is removed.
  4. Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 4, immagine 2 di 2
    • Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
    • Be careful not to pull too fast as there is still another cable attaching the keyboard.
  5. Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 5, immagine 1 di 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 5, immagine 2 di 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: passo 5, immagine 3 di 3
    • There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
    • Use a metal spludger to push the tab upward in order to release the cable ribbon.
    • Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
Conclusione
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 370
