Salta al contenuto principale
Toshiba Satellite L305-S5955 Wireless Card Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: passo 1, immagine 1 di 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 2, immagine 1 di 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: passo 3, immagine 1 di 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 4, immagine 2 di 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, immagine 1 di 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, immagine 2 di 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, immagine 3 di 3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 8, immagine 1 di 1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 9, immagine 1 di 1
    • Pull the card out vertically.
Conclusione
Samuel Baker
Membro da: 01/30/17
307 Reputazione
3 Guide realizzate
IUPUI, Team 1-2, Baechle Spring 2017 Membro di IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 820
