Salta al contenuto principale
Toshiba Satellite L305-S5955 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: passo 1, immagine 1 di 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 2, immagine 1 di 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L305-S5955 Keyboard Replacement: passo 4, immagine 2 di 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 5, immagine 1 di 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L305-S5955 Keyboard Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Chris
Membro da: 09/30/14
1 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Buehl Fall 2014 Membro di Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 958
