Salta al contenuto principale
Toshiba Satellite L305-S5955 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Complete these steps in reverse order to insert hard drive back into laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Eric
Membro da: 09/30/14
55 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Buehl Fall 2014 Membro di Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,010
