Salta al contenuto principale
Toshiba Satellite L305-S5875 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5875 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 RAM Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, immagine 3 di 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, immagine 1 di 3 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, immagine 2 di 3 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Toshiba Satellite L305-S5875 RAM Replacement: passo 4, immagine 1 di 3 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, immagine 2 di 3 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, immagine 3 di 3
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 20-5, Maness Winter 2013 Membro di Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 6,840
