Salta al contenuto principale
Toshiba Satellite L305-S5875 LCD Screen Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5875 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 LCD Screen Replacement, LCD Screen: passo 3, immagine 1 di 1
    • Open the laptop so that you can see the screen.
  4. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 4, immagine 1 di 2 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  5. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 5, immagine 1 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 5, immagine 2 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  6. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 6, immagine 1 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 6, immagine 2 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  7. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 7, immagine 1 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 7, immagine 2 di 3 Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 7, immagine 3 di 3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  8. Toshiba Satellite L305-S5875 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Congratulations, you have just removed your screen!
Conclusione
Now that you have removed the damaged screen, it is time to replace it with the new screen.
Follow these steps in reverse order to reassemble your laptop.
You have completed the LCD screen replacement guide for the Satellite L305-S5875. Great job!
Altre 2 persone hanno completato questa guida.
Un commento
My problem is a little different; mine broke near the hinge on the left side. So I need to remove the whole thing from the hinge up. Help?
DBethke1959@GMail.com
dbethke_1959 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,621
