Introduzione
If your Toshiba Satellite L305-S5875 keyboard is damaged or not working properly, it is fairly easy to replace.
Cosa ti serve
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
Altre 3 persone hanno completato questa guida.
