Salta al contenuto principale
Toshiba Satellite L305-S5875 CCFL Tube Replacement
Cosa ti serve
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 2, immagine 1 di 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 2, immagine 2 di 2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, immagine 1 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, immagine 2 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, immagine 3 di 3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, immagine 1 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, immagine 2 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, immagine 3 di 3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 6, immagine 1 di 1
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: passo 7, immagine 1 di 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: passo 7, immagine 2 di 2
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, immagine 1 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, immagine 2 di 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, immagine 3 di 3
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 9, immagine 1 di 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 9, immagine 2 di 2
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
Conclusione
Tyler
Membro da: 03/11/14
208 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 588
