Salta al contenuto principale
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
Cosa ti serve
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, immagine 1 di 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, immagine 2 di 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, immagine 3 di 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, immagine 1 di 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, immagine 2 di 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, immagine 3 di 3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: passo 3, immagine 1 di 1
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: passo 4, immagine 1 di 1
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: passo 5, immagine 1 di 1
    • Remove the board from the laptop.
Conclusione
Yanchen Li
Membro da: 01/22/20
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 346
