Salta al contenuto principale
Toshiba Satellite L15W-B1208X Battery Replacement
Cosa ti serve
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite L15W-B1208X Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, immagine 1 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, immagine 2 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, immagine 3 di 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, immagine 1 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, immagine 2 di 3 Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 635
