Salta al contenuto principale
Toshiba Satellite E45t-B4204 Speaker Replacement
Cosa ti serve
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, immagine 1 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, immagine 2 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, immagine 3 di 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 2, immagine 1 di 2 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 2, immagine 2 di 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, immagine 1 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, immagine 2 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, immagine 3 di 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, immagine 1 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, immagine 2 di 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 5, immagine 1 di 1
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speakers.
Conclusione
Emily Bateman
Membro da: 05/22/19
97 Reputazione
1 Guida realizzata
IUPUI, Team S3-G3, Wilson Summer 2019 Membro di IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Membri
6 Guide realizzate
2 Commenti
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.⏎
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.⏎
Any idea of what is the product code?⏎
Thanks
MagenOne - Replica
Looks this H000079200
MagenOne -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 695
